Funk owners
Al Sutrick
02-13-2001 17:42:19
Just a few questions. 1)Do you know what temp. thermostat you have in? 2) Does your tractor have a fan shroud? 3)If you still have 6 volt, does it start your 6 cyl. ok? 4) Do you have any trouble with overheating? thanks Al Sutrick
KCM
02-14-2001 16:12:14
 Re: Funk owners in reply to Al Sutrick, 02-13-2001 17:42:19
1) Don't know what they came out with, but 180 degree should work just fine.
2) A fan shroud was part of the Funk radiator that came with the kit.
3) The 6 cylinder will start on 6 volt, but starts much better on 12 volts, especially on cold days. If you have been around old cars and trucks, you'll know how hard it can be to get those old vehicles start on 6 volt.
4) If you have the bigger radiator that came with the kit, overheating is not a problem. I suppose that if you were working out in the field in 100 degree weather, then it might.
5) The stock 8N fuel tank and sediment bowl is used with the kit since the tank is raised up in the Funk kit, with only a new fuel line needed.
Rod Mi
02-13-2001 22:57:16
What kind of modifications dues the fuel system need can you use the stock sediment bowl to feed the funks? Thanks
Dave
02-14-2001 16:07:47
 Re: Re: Funk owners in reply to Rod Mi, 02-13-2001 22:57:16
I do not use a fuel shut off. I use an adaptor at fuel tank then I run 5/16 steel fuel line to pump and pump to carb.
