Way OT : Well Drilling
Alan
04-01-2004 09:46:18
I have never posted an OT subject but the N Board is such a great wealth of knowledge I figured this is great place to check this out....I would like to put a well near my cabin which is in a spot where a truck/rig cannot get too.....I was looking at the Hydra Drill 2000 ( I have seen their advertisments for years )and was wondering if anyone had any experience with this particular product or any other product that would be a portable well drilling rig....My soil is clay/shale no bedrock at least within the 10 foot or so that I know about.....Thanks....So as not to tie up too much space if you wish to reply I have put my e-mail address in....Thanks Again
ZANE
04-03-2004 07:54:22
 Re: Way OT : Well Drilling in reply to Alan, 04-01-2004 09:46:18
Got to thinking about your need to drill a water well and it finally came to my brain that I have just what you may want. It is a core drill that has not been used in years but is all there except for some hoses and the hydraulic pump that was driven from the PTO of the rig. It could be adapted to run off the PTO of a tractor. I had plans to do just such a thing and then we got the prospects of having the public water come by our place and I almost forgot about it.
There is about 80 feet of four and three inch drilling auger and the drill bit and a fishing tool to use if one of the augers were to come loose. It is in four or five foot lengths. The drill auger is turned by the PTO and the hydraulic cylinder is two ended and it goes up and down a three part track to raise and lower the drill stem into the ground and out.
Originally it was mounted to the back of a jeep and used by the county to drill for gravel etc. I got it at an auction and it has been sitting there for several years.
If you would be interested in it I can send you pictures.
It is big and heavy about six feet tall and three feet wide and about one and a half feet deep. The drill stems are all on a pallett.
Let me know.
Zane
Dave OH
04-01-2004 21:57:10
I couldn't get your e-mail address either. But mine should come up for a reply. Please let me know what your progress is if you do your project. I need a water source in the back field and would like to know if it works for you. I won't get to it probably till next year unless things go better than I expect this year.
Please send me a test message to my e-mail so I can give you another e-mail address, thanks,
Dave OH
ZANE
04-01-2004 12:47:07
Couldn't get your Email to come up.
Zane
ZANE
04-01-2004 12:44:07
You probably have the best strata possible to try the "Hydra Drill" system on. You will need a good supply of water to drill with and a good centrifugal pump to supply it with. You can catch the runoff water and reuse it if water is scarce but you do have to have lots of water down the hole.
I made a rig myself like the "DeepRock" drilling rigs that are advertised and it is like the "HydraDrill" system also.
Problem I had was that my strata was first clay and then gravel and then more gravel and sand and I couldn't afford the chemicals needed to hold the gravel and sand back when drilling and it kept falling back into the hole and slowing the progress. I did get down about 50 feet and had plenty of water but then again the fine silt in the water would plug the screen of the pump pipe and stop the water from flowing.
I think that I could have still used it if I had used the compressed air system to bubble the water up to the top of the casing and then pump it from a holding tank but I got discouraged and gave it up since at the time I didn't havbe the money to invest in a compressor.
The air pump system works by dropping a small pipe down inside the 2" well casing of about half an inch diameter and then blowing the water up casing with compressed air introduced at the bottom of the well. That was it is supposed to bring the sand up with the water and adjatate the water in the bottome of the well and prevent the sand and silt from being able to bridge the screen at the bottom of the well.
Also at the time I was working a lot to feed the family and didn't have the money or energy to keep experimenting.
I finally ended up running a plastic pipe 800 yars from a spring to a holding tank for our water.
We are supposed to be getting public water here this summer. YEA!!!
Zane
