Order Ford 8N Parts Online
8N-9N or 2N?? Identify
Sam F.
04-03-2004 13:08:00
How can I tell what this tractor is ?? Engine is stamped 8N199--- on block. Tractor, where do I look for serial number?? Just listed it for sale in photo ads. Help me identify, please. THANKS
Sam F.
04-03-2004 13:46:59
 Re: 8N-9N or 2N?? Identify in reply to Sam F., 04-03-2004 13:08:00
This narrows it down to either a 9N or 2N. Has 3 speed with single brake on each side. How do I go to next step and identify it as one or the other ???
roger '40 9n
04-03-2004 14:56:05
 Re: Re: 8N-9N or 2N?? Identify in reply to Sam F., 04-03-2004 13:46:59
One way to tell is to look at the Ford badge
on the front. A 2N will have a small 2N printed
under the word "Ford".
Another thing to look for is the shape of the radius rods. 9N's have I beam cast rods.
2N's have oval rods. There was some overlap so this is not definate --just a hint.
Some folks on this board say that the 2N' had holes in the lower section
of the front doglegs and the 9N's do not.
If you can find any casting date codes on your cast iron parts they can give some idea as to when yur tractor was built.
Roger in Michigan
EDDIE8N
04-03-2004 14:43:02
Sam,
Try this link.
roger '40 9n
04-03-2004 13:19:31
That is the serial number of the engine.
There are no other serial numbers.
However the 9n 2n 8n engines are interchangeable.
You could check for casting codes to date your tractor.
Some differences twixt the 9N/2N and 8N
9n/2n Three speed trans Rear hubs 6 bolt wide circle Left brake on left Right brake on right.
Draft control only
8N
Four speed
Rear hubs 8 bolt small circle
Both brake pedals on right side
Has both draft and position control (look for a little lever on the right side under the seat)
Roger in michigan
