For nearly every problem supposedly 'solved' with a chemical, you can find a better solution using an organic product. I don't know what you are trying to fix or cure with the Diazinon, but you do have other choices that are better for you and the chickens. I'm not a recent convert to the organic stuff, nor am I a tree hugger from downtown San Francisco. I use it because I have learned for myself that it works better than anything made by Scotts or any other chemical fertilizer or pesticide. Here are some good organic Web sites to check out: www.garden-ville.com www.dirtdoctor.com Go to the Organic Information Center, and find your subject listed alphabetically. Go to the links section to go to other sites. By the way, his links will take you to places where you can find things the chemical companies will NEVER tell you. For example, did you know there is arsenic and lead in the product called IRONITE, which is sold in nearly all of the big box stores? (Lowes, Home Depot, Wal-Mart, etc.) Did you know there are lawsuits against the company that makes it in several states? Good luck.
