How do you trickle charge a
4 2 N
04-05-2004 15:28:26
Hello, I know this is probably a stupid question, but what clamp (positive or negative) do I put on my postively grounded 6V "N" battery? I tried to use the 6V crank setting on my charger to get a dead battery going and when I hooked the positive clamp to the positive terminal it sparked and didn't seem quite right. Sorry if this is a no brainer, but when it comes to 6V system, I don't have much experience, it has just always worked. Thanks very much.
4 2 N
04-06-2004 13:12:23
 Re: How do you trickle charge a in reply to 4 2 N, 04-05-2004 15:28:26
Thank you for all of the advice. I am luckier than I thought. I've never had a major problem before, but I guess that was dumb luck. Thank you for the safety tips. They were probably printed on the old charges somewhere, but have long since disappeared. Thank you for your replys.
paul
04-06-2004 10:39:29
You wanted to trickle charge, not feed 50-100 amps to a dead battery! No wonder it sparked. Use a much lower setting, + to +, and so on as the rest have said.
I had a battery short internally & blow up under me on the 960 Ford. Hearing came back in 5-10 seconds, the sheetmetal protected my face as the top blew off. Acid was dripping everywhere.
Have a WHOLE new respect for that issue, but folks have to see it for themselves before they respect this. Only happens one in a thousadnd, but wow is it spectacular when your number comes up! :)
--->Paul
txblu
04-06-2004 09:44:36
I am reading contradictions I think. I read "trickle charge" and then "6v Crank" and sparking.
1. As posted by Dave and roger, + to + and - to - regardless of how it is hooked up in the equipment. You are charging the batt, not running the equip.
2. Safety 1st, so as mentioned, no sparks. Best way to do that is to insure your charger is unplugged before hooking up to and removing from the batt.
3. I assume your spark came from an energized charger, with the 50 amp (100 amp on 6 v) button in the on position and the minute you got the second lead on the batt it delivered what you told it to....50 amps. DON'T do that. You will make a very bad mess for you and your equip.
4. Trickle charge is on the order of 1 amp or slightly higher with preferably a very accurate voltage monitor in the charger that knows when your batt drops 0.2 v or so and kicks the 1 amp back in and out as the voltage fluctuates.
So 4 2N, with that said did we answer your questions or are we on different sheets of music?
txblu
Dave OH
04-05-2004 20:07:44
As "Roger" said. Except NEVER hook up a charger that is plugged in.
If you had been charging and the gas had collected the battery could have exploded from the spark. Safety First.
Dave OH
roger '40 9n
04-05-2004 15:41:36
Positive to positive
Negative to negative
ALWAYS
If you had a dead battery i would expect a spark.
Roger in Michigan
