Grinding clearance notch for starter
Phil
04-06-2004 08:13:46
I read in earlier posts that a notch can be made in the bell housing to ease starter replacement. Can Any of you knowledgeable guys help a suffering newbie? Tried about everything else. Thanks!! - phil
Enumclaw
04-06-2004 08:50:52
 Re: Grinding clearance notch for starter in reply to Phil, 04-06-2004 08:13:46
Yep, at about the 2 o'clock position you can grind 1/4" or more away, makes it a heck of a lot easier to reinstall the starter. I used a rotary file on my cordless drill. Quick and easy.
Rob
Phil
04-06-2004 09:04:39
 Re: Re: Grinding clearance notch for starter in reply to Enumclaw, 04-06-2004 08:50:52
Thanks rob, are we talking about notching the the starter hole or the ridge I see inside the housing opposite the flywheel? Thanks!
Enumclaw
04-06-2004 12:31:42
 Re: Re: Re: Grinding clearance notch for starter in reply to Phil, 04-06-2004 09:04:39
What Soundguy said.....!
Rob
souNdguy
04-06-2004 10:35:31
Sit down on the ground staring into the empty hol ein the tractor where your N starter goes. Hold your watch so that is is the middle of the opening... look over to where 2'oclock will remove about 1/4" from the opening starting just before 2 position.. and a bit after it... this will leave you with a slightly irregular eliptical hole, that wides up and to the right.
Also.. is your bendix in its full 'back' position a tthe end of the shaft? if it isn't .. you will be there a long time getting it installed.
Soundguy
phil
04-07-2004 08:47:50
 Re: Re: Re: Re: Grinding clearance notch for start in reply to souNdguy, 04-06-2004 10:35:31
Ok will try this weekend. should work fine but curious as to why it wasn't designed right in the first place. Oh well thanks for all you help!! Its appreciated. -- PHIl
souNdguy
04-07-2004 10:58:14
 Re: Re: Re: Re: Re: Grinding clearance notch for s in reply to phil , 04-07-2004 08:47:50
The starter will install correctly without the widening.. but you have to hold your mouth just right, and a bunch of other variables need to be perfect..( stars lined up... seventh son of a seventh son.. etc! )
Soundguy
