Order Ford 9N Parts Online
9N Front Wheels
San F.
04-06-2004 14:13:40
I have a 9N around '40-'41 model with the wide front bolt pattern. Of course it has car tires on it. The wheels are 16 inch but have not had the rims welded off car to the centers. The rims to centers are riveted. Are these original ?? Could e-mail inside and outside picture if it would help. THANKS
SteveB(wi)
04-06-2004 19:49:49
 Re: 9N Front Wheels in reply to San F., 04-06-2004 14:13:40
They are probably late 30's Ford car/truck rims and for them to work without being welded to the center they would have swapped out the hubs too. These hubs will direct fit on the tractor. Look for brake drum evidence on the hubs. I can't remember the exact numbers but the truck/car bolt circle is like 9+" and the 9N/2N is like 10+".
Sam F.
04-07-2004 20:10:51
 Re: Re: 9N Front Wheels in reply to SteveB(wi), 04-06-2004 19:49:49
Steve: Just checked and the hubs have 10"+ bolt circle. I have another 9N with the same hubs and the rims have been welded. The center cap on the hubs in question is a square head with looks to be threaded on.(unsure) Hub is cast metal with no signs of brake drums. No what?? Is there any cast # on the hubs ??
