Order Ford 8N Parts Online
O.T. '49 8N Bushhog blade removal - Part 2
RuintTx
04-14-2004 02:46:14
Thanks for all the great ideas, I knew this board would come through for me! I ended up borrowing an 8 foot / 3/4" dr. torque handle from work to get those 2 nuts off. I ended up with a cheater bar on it! Bent it, but broke the the torque, or so I thought. Turns out the bolts are now spinning and since they have a round head I am losing interest in replacing the blades and sharpening them installed on the hog looks like a better idea. Thanks again for all the great input.
RuintTX --'49 8N #231880
CAUTION . . . Dell (WA)
04-14-2004 08:29:48
 Re: O.T. '49 8N Bushhog blade removal - Part 2 in reply to RuintTx, 04-14-2004 02:46:14
Ruint..... ....CAUTION: iff'n ya bent a 3/4" cheater bar, ya probably "cracked" yer brushhogg bolts. And they will BREAK from centrifical force at some un-opportune time, sending yer brushhogg blade FLYING THRU sumptin. NOT PRETTY.
DO THE RIGHT THING.....gitta flame-wrench out and cut them suckers off and replace them with new blade pivot bolts..... ...Dell, the self-appointed safety preacher
DD8NMi
04-15-2004 09:34:28
 Re: Re: O.T. '49 8N Bushhog blade removal - Part in reply to CAUTION . . . Dell (WA), 04-14-2004 08:29:48
A big AMEN to the preacher for that one. Get those bolts out of there and put new ones back in!!
On the other hand a 20 pound chunk of sharpened steel going off in an unknown direction at a high rate of speed could cause a little excitement.....Just hope you are no where around my place!!
Rick H. Ga.
04-14-2004 05:07:53
I admire you for attempting to do the job yourself. It shows courage and determination.
When I read your post I thought about an experience I had once involving replacing a set of bush-hog blades.
Here is the story I posted a few years ago on the N board.
My first bush hog for my 8N was a used 4 footer that I purchased at the local Ford (back in 1977) tractor dealership for $150. It worked fine for a couple of years. When it seemed to quit cutting as smooth as it previously did, I discovered that the blades were worn out and beyond sharpening. I didn’t have a socket big enough to fit the big nut on the pin that held the blades on the stump jumper. I decided to take it back to the tractor dealership and let them put new blades on it. (I was willing to pay the cost) When they called and said it was ready I went back to pick it up. I was excited about my new blades on my hog. I immediately connected it to the 8N and started hogging and noticed that it wasn’t doing such a good job. In fact, it was worse than it was with the worn out blades. Upon further investigation I noticed that the blades were turning in the opposite direction of the cutting edges of the blades; they were turning backwards. (It was apparently the wrong set of blades for that mower.)
I called the dealership and informed them about the problem. They offered to come and pick it up, fix the problem and bring it back for free. However, instead of installing the correct blades, they simply inverted the same set of blades. The problem with this was that since the blades were offset, the cutting edge was now facing the right direction of rotation but they were up side down. I called them back and they said they would come and get it the next day but they couldn’t guarantee they could find the correct blades.
They finally found a set of blades sharpened on both sides that worked.
The moral of this story….. paying a high price to get competent, professional service does not always ensure competent, professional service. .
Rick H. Ga.
DJ in Pa.
04-14-2004 04:26:54
Angle grinder , sawzall , air chisel ,torch , These are all good 5 minute nut removers!
Stan(PA)
04-14-2004 08:07:14
 Re: Re: O.T. '49 8N Bushhog blade removal - Part in reply to DJ in Pa., 04-14-2004 04:26:54
Many years ago, I had a nut "splitter". Worked good for regular sized nuts. Are these things still around, and do they come in bigger sizes?
It was just a sharp/hardened chisel head that clamped, and as you tighened it, the chisel split the nut. Normally, threads were not damaged.
souNdguy
04-14-2004 11:21:56
 Re: Re: Re: O.T. '49 8N Bushhog blade removal - P in reply to Stan(PA), 04-14-2004 08:07:14
Yes.. nut splitters are still around.. but one for a hardened 2" nt will be difficult to put your hands on.. easier to angle grinder it off..
Soundguy
Dan
04-14-2004 05:38:49
I agree, if you can find replacement bolts and nuts - just cut/torch the old ones off and be done with it.
Good luck,
Dan
