Order Ford 8N Parts Online
Changing the front tire on a ford 8n
Richard
04-23-2004 17:23:08
Where do you suport the front when you are changing the front tire on a 8N ? is the underside of the oil pan strong enought? or is their a better way. thanks for your help
Dell (WA)
04-23-2004 23:58:29
 Re: Changing the front tire on a ford 8n in reply to Richard, 04-23-2004 17:23:08
Richard..... ....it should be intutitively obvious that your loosen yer frontwheel lugnuts BEFORE you jack-up your front axle. While I have a floorjack, I still use a block of wood to distribute the pressure on the castiron oilpan or the frontaxle support assy. Then jack-stands under the axle for final stablity..... ....Dell
Rusty
04-23-2004 18:34:02
You can put it under the pan with a wood block between the jack and pan. Or just in front pan on the axle support. I like to jack under the axle support and set it down on jack stands, blocks of wood, railroad ties etc. under each axle.
Richard
04-23-2004 17:40:30
Thanks Bruce for you advice what I am trying to do is pull both tires off and have them replaced they are completly worn out maybe it would be better do one at a time thanks again these tractors are the greatest Richard
Bruce (VA)
04-23-2004 17:31:23
The oil pan is probably strong enough, but the problem is that the front axle is on a pivot pin; if you get both wheels off the ground at the same time, the axle flops around like a see-saw. Put the tractor in gear, block the rear wheels, and place your jack under the front axle about half way on the side that you are removing the tire.
