Order Ford 9N Parts Online
9N 12v
Al
02-15-2001 19:29:17
I got a 12v coil. Do I keep the resistor on the terminal block or bypass ? Would that keep it from starting if I kept it or fry my coil if I removed it? ?
Also, does the condensor have to be a 12volt ? Some body here said youdont even need a condensor to start just to protect the points.
Phil (AZ)
02-15-2001 20:02:02
 Re: 9N 12v in reply to Al , 02-15-2001 19:29:17
AL, You need the condensor! without it most of your
hi-voltage (ultrahigh without condenser) won't make it to the sparkpugs.
If the current on your ammeter without the Ballast
is about ~ 5 amps. (points closed) You will be OK
JMHO
