Order Ford 9N Parts Online
9n
piro
04-25-2004 13:25:24
put a new starter in,starter turns then locks up,the engine will not turn over using the crank,i have to remove the starter then its fine. any ideas guys ?
Scott
04-25-2004 15:31:39
 Re: 9n in reply to piro, 04-25-2004 13:25:24
Check the teeth on the flywheel, if they are damaged at 2 places opposite each other around the flywheel it needs split to replace the gear.
