Obi-Wan, I read your post about your tractor problem, you said, "about 20 minutes into another lane-grading session, the engine suddenly started to sputter & die. My Dad was able to keep it running long enough to drive it home by holding the choke closed, but it ran really bad." These guys on here are great!! Many more years experience than I have. But, I had exactly the same problem with this Ford I got , before I got it. One day up at my brothers place, it did the same thing. I was able to keep it running, like you did, hold the choke closed some. The guy he got it from just happen to show up and said he had the same problem and had rebuilt the carb. Ok, Long story, but here is what we did. Took the carb off the tractor and onto tailgate of pick up. Pulled it apart. Everything looked ok, nice and clean , good fuel flow from gas line, float not sticking. What we found was, on the butter fly inside the carb was a smaller spring loaded butterfly flap ON the main flap. The chock flap. Confused? Wish I had a pic of it. Anyway, we discovered that the little flap was spring loaded and the spring was bad, it was pulling the little flap closed and causing the problem. After we removed that little flap and bad spring, and put the rest of the carb back together, it ran fine. ( I also removed the choke cable, just because). Tractor runs fine, never a problem since. Just what I did, am sure your fix will be pretty easy, once you look at it.
