Oil for governor
Roger Myers
04-30-2004 11:34:29
In the 9N governor reservoir, what wt. oil should a guy use - 30w non-detergent? I would assume that when changing out the governor I should drain all that oil also. Roger
Mr Bill No. Mn.
04-30-2004 18:16:07
 Re: Oil for governor in reply to Roger Myers, 04-30-2004 11:34:29
You aren`t a dummy you are learning like the rest of us. We all go thru that and don`t let anybody tell you different. Anyway keep up the good work.
Dell (WA)
04-30-2004 11:56:46
Roger..... ...unless you have a VERY EARLY 9N, the governor is lubricated by the oil drain from the oil filter canister.
And iff'n you really do have the early 9N un-lubed governor, which is actually ineffectively splash lubed by the crankshaft oilslinger with engine oil, recommend you consider the merits of a field retrofit to the later governor oil scheme by re-plumbing the oilfilter drain to a NEW GOVERNOR CUP..... ....Dell
Roger Myers
04-30-2004 13:10:51
 Re: Re: Oil for governor in reply to Dell (WA), 04-30-2004 11:56:46
Thanks, Dell. That's what it is doing, getting oil from the filter cannister. After posting this it all dawned on me. I'm just slow - and stupid. Thanks for putting up with this ol' dummy. Roger
