used rims?
-bill
05-03-2004 10:57:40
I'm switching from AG tires to turf tires (placating the wife who hates it when I drive across the lawn). Two questions:
1. What width rims? I see you can buy new in 10", 11", and 12" widths. Will a Titan R-3 fit on 11" rims?
2. Where's the best place to find used rims?
thanks,
-bill
doc
05-04-2004 16:07:21
 Re: used rims? in reply to -bill, 05-03-2004 10:57:40
What are you going to do with ag tires and rims?
Are they in good shape, are you going to sell them?
bill
05-05-2004 04:15:00
 Re: Re: used rims? in reply to doc, 05-04-2004 16:07:21
Doc,
I hadn't given it much thought. I'll probably keep them and use them in the spring when nothing but AG tires will get through the silt mud we endure here in the former basin of the St Lawrence sea.
T.S.Dye
05-03-2004 20:11:09
Keep in mind that if your going to use turf tires you wont be able to chew tobacco,because if you spit in front of the rear tire youll be stuck. T.S.
Mike S
05-03-2004 11:21:23
You might try a tractor dealer and see if they have any used ones. I bought two of the later model 6 loop kind for 100 bucks at a tractor junk yard in AL a few years back. 11 inch wide. I bought my rear 13.4 x 28 turf tires used from a NH dealer. They were takeoffs from a 3930. I used some 4x19 motorcycle motor cross tires for the front. I turned the toe-in to toe-out about 1/4" and I don't put a mark on the lawn when I mow.
