Hi Guys. I am in the final stages of reconditioning my 1948 8N. The engine has no serial number, but there was an aluminum plate braded to the top of the bell housing, that isunreadable due to age and excessive heat. It is possible that this engine was an industrial engine, moved over to my tractor by a former owner. I do have the year 1948 cast in the left rear axle housing, and a front mount distributor. The engine governor is my problem. It is unlike the governors shown in the I&T FO-4 manual. Mine has an adjusting bolt with lock nut in the center of the housing. This adjustment bolt applies tention to a U shaped spring (internally) that inturn applies tension to the throttle lever (the outer lever). For more identification information, there is no proofmeter connection on this governor. My problem is: Too much throttle when the hand throttle lever is in the last positon (Idle position). I can't get the throttle lever on the governor to relax to the idle position. It seems to always have tension on it wanting to increase engine speed. And, there is no adjustment on the governor to carburator linkage, so I can't adjust the linkage. It is a solid steel rod with no threads like the hand throttle to governor linkage. my questions are: 1. Has anyone seen this style of governor, and do you understand this style of governor? 2. Where do I find printed information on this style of governor? If I can't find printed information on this style: 3. How do I adjust this governor to allow the engine to idle, and to operate properly through the range of hand throttle settings? Thanks in advance for your help on this. Rustynails
