Order Ford 8N Parts Online
8n pressure plate problems
Rich
05-05-2004 07:21:41
I just replaced the clutch pressure plate,pilot bearing and throwout bearing and it still won't work right. I put the tractor back together and made adjustments to the pedal yoke and it still won't go into gear because the clutch and pressure plate are pressed together. I split the tractor again and when taking the pressure plate (PP) off I noticed the 3 PP fingers lifted up the more I loosened the bolts. I need help on what to do now. Thanks, in advance.
Dell (WA)
05-05-2004 08:36:08
 Re: 8n pressure plate problems in reply to Rich, 05-05-2004 07:21:41
Rich..... ...take a sidewize look at yer clutch disc. The sliding hub is "off-set" and the longside should be tranny side. I'm assuming that you have the 9" disc with 10 spline 1-3/8 hub and NOT the 10" HD disc with 10 spline 1-3/8 hub that fits the NAA.
I'm assuming that you realize that pressing on the clutch pedal pushes on the pressure plate arms and releases the pressure plate spring pressure on the clutch disc so you can shift yer tranny gears.
There was a recent report that somebody got a new replacement clutch disc where the actual lining was "too-thick". Unfortunately, I don't have the thickness specs for clutch lining. Try a different clutchplate vendor? Take a lining thickness measurement to compare..... ....Dell
