This spring, I replaced the plugs & wires and cleaned out the fuel line/filters on my dad's 1943 2N. It ran great for a while, but about 20 minutes into grading the lane recently, it started acting really bad. My dad was able to limp it back home by holding the choke open.I figured it was a heat-related problem like the ignition switch, but when I started it up cold yesterday, it still ran very bad & needed the choke to stay running. As I turned it off after 30 seconds of running, I noticed a fair amount of exhaust-like smoke eminating from where the #1 exhaust manifold port meets the head. No apparent leaks or cracks there, though. I checked the fuel lines, and they're still clean. When I checked the coolant, it was about 3 qts low. My fear is that my dad overheated the engine and cooked a valve or something. Is this likely? I'm gonna pull off the distributor and carb today and check those over. I could probably do a compression test on the #2-4 cylinders, but removing the #1 plug is quite difficult due to the location of the bracket for the 12V alternator (it requires draining the coolant and removing a head bolt that runs into the water jacket. The ignition switch is basically clean and looks fine at a glance. All the wire connections are clean. The balast resister was removed during the 12V conversion. Any ideas?
