Order Ford 8N Parts Online
8N Hyd Lift
Ralph 8N
05-07-2004 03:59:06
Well, I have adjusted the height as suggested sometime ago. Still have a problem lifting anything really heavy. I have a 5'Rebel Bush Hog it will not lift off the ground. If I leave the lift control all the up and lift the mower by other means it will hold it up. And still it does not lift all the way with the same strength.
How much weight is supposed to be able to lift?
roger '40 9n
05-07-2004 05:14:09
 Re: 8N Hyd Lift in reply to Ralph 8N, 05-07-2004 03:59:06
You should be able to lift about 800 lbs
before your front wheels come off the ground.
Someone on this forum chained down the front
of their N and was able to lift 1200 lbs.
before the safety valve on the hydraulics
opened up.
Roger.
