Order Ford 8N Parts Online
Changing Hydraulic Fluid on '52 8n
Novice8nOwner
05-07-2004 12:55:30
I need some help from the experts. I found nothing in the archives on what size wrench needed for the three plugs containing the hydraulic fluid. I'm sure it's pretty standard, but any input would help.
Thanks,
The Novice
Rob
05-07-2004 16:27:30
 Re: Changing Hydraulic Fluid on '52 8n in reply to Novice8nOwner , 05-07-2004 12:55:30
Had all my drain plugs off this last few days. 10" cresent wrench did the job but if they are fouled up it might take a hammer and chisel to convince them to start moving the first time.
I put mine back on with good gaskets, clean mating surfaces, hand-tight then 1/4 turn with aforesaid cresent and nothing leaked. None of them have the corners knocked off though.
souNdguy
05-07-2004 20:44:57
 Re: Re: Changing Hydraulic Fluid on '52 8n in reply to Rob, 05-07-2004 16:27:30
Yep.. I believe that was the size I used too.. 10" crescent wrench..
Funny.. seems to fit 'most' of the bolts on all my tractors
Soundguy
Gaspump
05-07-2004 15:51:21
Hey Novice, engine drain plugs are square, tranny and hydraulic pump plugs are 1-1/16" hexagon as are axle bolts,rear lugs, etc, etc. Go with a 1-1/16" socket and long breaker bar or impact wrench, your choice. Don't forget the plugs are upside down so don't force them the wrong way!
BillM (OH)
05-07-2004 14:58:35
What Jeb sez -- and if you have trouble holding the pipe wrench on use a bottle jack with a piece of 2x4 to hold the wrench on the square nut. If it's really tough, piece of pipe for a cheater or sledge on the pipe wrench.
Jeb2N
05-07-2004 13:48:53
Adjustable, pipe wrench, hammer/chisel. Your choice. Just grab something that fits the square heads and go with it. Advise you use penetrating oil on them because a few have a tendancy to get stuck really good.
