Drown 2N lives again
RussMO
05-07-2004 15:08:58
Well after all the initial work reported eariler, I started to look into the wiring to determine why it would not start.
I failed to mention that the unit was running on a 6volt coil I had in the barn before converting to 12volts. The 12volt coil was bad so I replaced it with the old 6volt. It was running great until the lake adventure.
Today started early and did the following:
-checked voltage at coil on distributor and nothing. Remove the coil from distributor and reads normal. (strange)
-replaced ballist resister last week, and replaced the other one today. Still nothing.
-got in trash can and found old 12volt coil that was replaced with the 6volt coil, installed, and it kicked right off. It would only run at idel.
-Went to New Holland and bought a 12volt coil and it runs "GREAT"
Thanks everyone for the help
Ken N Tx
05-08-2004 02:58:35
 Re: Drown 2N lives again in reply to RussMO, 05-07-2004 15:08:58
third party image
Hey Russ, was this your next step ???
RussMO
05-08-2004 05:47:18
 Re: Re: Drown 2N lives again in reply to Ken N Tx, 05-08-2004 02:58:35
I did come very close to pulling her back down to the lake..... .
Rob N VA
05-07-2004 18:50:28
Amazing machines, aren't they? Congratulations on getting her running again. Now you know you can take her swimming anytime you want :) Maybe even the beach!!
----Rob
