Order Ford 8N Parts Online
Tie Rods on 8N
Phil@Tex
02-18-2001 16:14:00
I'm looking to replace the tie rod ends on my 8n. So far I haven't been able to find any like the ones I have. The rear ball joint is welded to a solid rod better than 24" long with a 11" sleeve on the end that the front ball joint screws into. So far all I've been able to find is the sleeves and balljoints with 4" or so inches of thread. Does anyone carry the ones like mine with the rear ball joint on a 24"+ threaded bar? (just the end is theaded for the sleeve)
Claus
02-19-2001 04:44:15
 Re: Tie Rods on 8N in reply to Phil@Tex, 02-18-2001 16:14:00
To my knowledge, no one make these. When I replaced mine, I replaced them with the short ends and got long tubes instead of the welding route.
Happy Motoring
Claus
Rick(Ga)
02-18-2001 17:46:08
I receintly had the same problem you have. The local FNH dealer said they could order the exact replacement but they were well over $150.00. I opted to buy the short balljoint ($11.00 ea.) and cut the old ones off and weld the new ones on. It worked fine. After I welded the new balljoints on I grinded the excess weld and repainted. Looks professionaly done. I'm sure Don @ just 8n's can get you the exact drag link if you want. Rick(Ga)
