Replaced chamber gasket on belly pump.
Rob
05-15-2004 17:21:26
Had one blow a chunk out. Guess it was the chunk of gasket that clogged the control valve that made my lift go up and not come down. Anyway, I think I believe I found the reason the gasket blew: 20ft/lbs of torque on the chamber assy bolts. All of them, both chamber assemblies.
Those are 7/16" hardened bolts good for 85ft/lbs anyway. I couldn't find a torque spec in my Ford stuff so I put 80 on them, figured that was way better than 20, and put it back in the tractor.
The good news is that with the good gasket my lift will lift me @ 400rpm engine speed. I don't weigh much but that seems pretty good, I'm happy.
Russ in SoCal
05-15-2004 21:18:36
 Re: Replaced chamber gasket on belly pump. in reply to Rob, 05-15-2004 17:21:26
Rob,
80 prolly work, but.... Dell's pretty sharp on tech stuff, too. (Once ya translate the "Redneck" into English.)
Russ
