Tire pressure!
8-N Nut
05-17-2004 22:06:58
How much air do you guys put in your trailer tires, when hauling your 'N' tractor? TIA
Lee
05-18-2004 11:47:47
 Re: Tire pressure! in reply to 8-N Nut, 05-17-2004 22:06:58
Like Stumpy said, I usually use the pressure listed on the tire sidewall as maximum. If I recall correctly mine are around 40 or 42 lbs.
Good Luck, Lee
Stumpy
05-18-2004 03:20:17
Sidewall pressure. Tires are rated to carry there max weight at max press. Always check press. before the tire is worked(hot). The air will expand as a loaded trailer is towed down the road. Low tire press can overheat the tire and cause a blowout. This is the leading cause of truck tire failure, not the bad rap most people give to recaps.
Stumpy
8-N Nut
05-18-2004 17:52:05
 Re: Re: Tire pressure! in reply to Stumpy, 05-18-2004 03:20:17
Thanks Guys! Followed suggestions! Hauled a Ford 4000 out of mountainous winding roads. Fifty mile run. No problems!
