tranny follow-up
nut
05-18-2004 07:45:04
Thanks for the advice on the milky tranny fluid. I checked the boot around the shift lever and it looks good, no cracks and seems sealed good. There is, however, a old floor mounted push-button ignition switch located right next to the shift lever. that button is darn loose. Could this be a possible water entry point? I tried to tighten it by hand but it just kept spinning like it had stripped threads.
Dell (WA)
05-18-2004 09:42:16
 Re: tranny follow-up in reply to nut, 05-18-2004 07:45:04
Nutzie..... ....the 8N push-button starter switch by the tranny shifter lever is supposed to be the "safety-interlock" for starting in neutral. It is held inplace by a nut inside the tranny shifter plate. And iff'n you decide to remove the shifter coverplate, watch out for flying springs and detent balls. (cover everything with big rag to catch'em)
And yes, the starter pushbutton can be a "source" of hydro-tranny fluid water contamination. Altho the rubber shifter lever boot is usually the most likely suspect. ($3, cheap) Tip: BOIL rubber boot in hot-water so it will stretch over the tranny shifter tower..... ...Dell
