Air cleaner oil?
Adam
05-20-2004 10:38:36
What weight oil is recomended for use in the air cleaner on my 8n.
Any help would be great.
Charles (in Ga)
05-20-2004 20:56:36
 Re: Air cleaner oil? in reply to Adam, 05-20-2004 10:38:36
I go one better, When I change oil, I turn up the bottles in a container with a lid with holes in it. The oil bottles stay there and drip out till the next change, when I throw them and put more in their place. You would be surprised how much oil you can recover that way. Its a mix of everything but perfectly acceptable for the air filter sump.
Its good for the enviroment, doesn't add oil to landfills, and saves me a dollar or two. Leave the caps off the bottles when they go in the trash, they crush easily in a landfill that way, they won't if you screw on the caps. That goes for soft drink bottles and such too.
I've often wondered if chainsaw bar oil would be good, its so sticky, might need diluting though.
Charles
Ron from IL
05-20-2004 10:45:41
The same as you use in your crankcase.
Adam
05-20-2004 10:48:26
 Re: Re: Air cleaner oil? in reply to Ron from IL, 05-20-2004 10:45:41
Thanks
