Archives down-Universal transmission fluid
Rob N VA
05-23-2004 20:59:25
I changed the rear/tranny fluid on the 8N this past weekend. First time I have done it. I used the universal fluid they have at NAPA. I just wanted to double check to see what you guys think of the stuff. I would have searched the archives, but they are down right now. Thanks for the advise!!!----Rob
Bob
05-23-2004 21:06:34
 Re: Archives down-Universal transmission fluid in reply to Rob N VA, 05-23-2004 20:59:25
Universal transmission fluid typically is labeled to met the Ford "134" specs. Is yours so labeled?
Rob N VA
05-23-2004 21:10:14
 Re: Re: Archives down-Universal transmission fluid in reply to Bob, 05-23-2004 21:06:34
YESSIR it is. Just double checking. Thanks for the quick reply----Rob
Bob
05-23-2004 21:29:38
 Re: Re: Re: Archives down-Universal transmission f in reply to Rob N VA, 05-23-2004 21:10:14
Well, it should do the job for ya, then!
Dell says I'm a nut because I still like the 90 weight oil. I just use my 'N in the summer, and am well satisfied with the hydraulic performance and the fact that it is less leaky than the thinner stuff, especially in hot weather, but to each their own!
On the subject of the "134" type oil, I am almost certain that Deere Hygard and Case IH Hytran also meet the Ford "134" spec. Can anybody confirm that?
Geo in SD
05-24-2004 10:19:18
 Re: Re: Re: Re: Archives down-Universal transmissi in reply to Bob, 05-23-2004 21:29:38
They are about the same and meet 134 specs. I use Hy-Gard in my three Fords, havn't had any problems yet.
gahorn
05-25-2004 11:21:08
 Re: Re: Re: Re: Re: Archives down-Universal transm in reply to souNdguy, 05-24-2004 06:37:45
Well, I've read all the stuff about GL-5 being corrosive to "yellow metals" i.e., bronze, etc., ....but can anyone tell me exactly what parts in the N-series trans ARE actually "yellow"? Those are usually syncronizers, etc., but this is a non-sync trans., right?
souNdguy
05-25-2004 11:32:37
 Re: Re: Re: Re: Re: Re: Archives down-Universal tr in reply to gahorn, 05-25-2004 11:21:08
Hydraulic pump components.. and bushings.. etc.
Soundguy
