Top Link Length
Richard Fazio
05-24-2004 06:49:54
Could someone tell me the length of the top link at it's shortest and longest? I want to get a cylinder to go in where the top link fits and I forgot to measure it this weekend. Thanks.
Erik Graham
05-25-2004 06:54:04
 Re: Top Link Length in reply to Richard Fazio, 05-24-2004 06:49:54
Richard;
I did a bit more measuring and this is what I came up with. The hydraulic top link now is 21" center to center. The cylinder I used is an 8" stroke and a 2"bore. In theory that should give me a range of lengths from 21" to 29". I also measured the offcut from the ram and it was 2". The 23.50" top link length I mentioned in the previous post is the length at which the bottom of my dirt scoop sits parallel with the ground. By shortening the top link I am hoping that I can get enough tilt in the scoop to avoid dribbling the load out in the journey from A to B-much the same way a front bucket is tilted back. Hope this is what you require. Cheers, Erik
Erik Graham
05-24-2004 08:50:47
Richard;
I just made these measurements on my tractor, I'm sure there are some minor variations from impliment to impliment. My tractor is a '53 Jubilee and from the center of the hole on the rocker to the center of the mounting hole on my dirt scoop is 23.5" I ended up having to shorten the cylinder ram by about 1-1/2" in order to get that closed measurement below the 23.5" as I want to be able to tilt the scoop back a fair amount and the only way to do that is to shorten the top link.I also had to compensate for the extra length incurred by welding on a ball link on the end of the ram. Hope this helps.
Cheers, Erik
Richard Fazio
05-24-2004 08:56:48
 Re: Re: Top Link Length in reply to Erik Graham, 05-24-2004 08:50:47
Erik, do you mean the 23.5" length is the shortest you had to go? That would mean the longest was probably another 8" or 10" or so right?
