Order Ford 8N Parts Online
How to tell the diff. from a 2N--8N or 9N?
Ron
05-26-2004 09:55:02
Is there any way to tell the diff. from these three models? I bought a Ford last night got to pick it up this week end,its got the dist. right below the water pump and a (round rods for peddels) the right brake then on the left hand side its got the left brake and also on the left hand side the clutch peddel.Also where is the serial number plate located?
Thanks
Ron
Ron
05-27-2004 10:09:29
 Re: How to tell the diff. from a 2N--8N or 9N? in reply to Ron, 05-26-2004 09:55:02
Thank you guys for all the information! I got some real good web sites from your responces...And cant wait to Sat to go pick up this tractor. I dont have any FORDS in my flock this is the FIRST FORD! I have a J.D."B" J.D."M" J.D. 40 Crawler 2- Case "VAC's" Case "VAI" Oliver "O.C.3" 2 Cletrac "H.G.68" and a Teritrac "G.T.30". So I hope this FORD feals rite at home in my barn. Seems like you Ford collectors have a good web site on here with lots of help and information posted.
THANKS
Ron from Pa.
Dell (WA)
05-26-2004 10:17:50
Ron..... ...heres yer biggest clue ONLY 8N's have 4-speed trannys and they also have side-by-side rightfoot brake pedals. 9N/2N's have 3-speed trannys and straddle brakes.
Yer descriptions of round footpegs is consistant with 9N/2N's. All 2N engines s/n start with 9N. Engine s/n's are lightly stamped on a 1x3 flatspot under the cylinderhead seam next to the lefthand oilfilter canister. Engine s/n's are listed on the leftsidebar Research and Info "serial numbers"..... ...goodluck, Dell
Steve(OR)
05-26-2004 10:12:26
Brake pedals on opposite sides indicates 9N or 2N. Go to the link to learn more. If it doesn't already have it you will probably want a position control device. When the archives come back up do a search on Zane Thang (yes "Thang" is correct) to learn more.
ED-IL
05-26-2004 10:11:25
SN on engine, above starter.
8N had 4spd tranny and position control - earlier had front mount dist, later had side mount
9N # 2N almost identical - earlier had I beam radius rods to front axle - late 9N & 2N have round radius rods.
Early 9N had non pressurized radiator and smooth rear hubs. Late 9N and 2N had riveted hubs and presurized radiator
George Willer
05-27-2004 07:10:17
 Re: Re: How to tell the diff. from a 2N--8N or 9N? in reply to ED-IL, 05-26-2004 10:11:25
There is no absolute defining difference between the 9N and 2N, except for the true 2N with magneto and steel wheels. The tractor built in 1943 was identical to the 1941, until the radius rods were changed to tubulat late in 1943.
I don't know exactly when the rubber steering wheel spokes and the dogleg attachment changed, but every year saw minor production changes... hardly enough to make a new model.
roger '40 9n
05-27-2004 15:15:57
 Re: Re: Re: How to tell the diff. from a 2N--8N or in reply to George Willer, 05-27-2004 07:10:17
George Willer wrote:
"There is no absolute defining difference between the 9N and 2N"
The one that i know of is the Ford hood badge on the 2N has a tiny 2N printed on it.
Others have said the the 2N had holes in the lower front doglegs and the 9N does not.
Roger in Michigan
( PIC ) Ken N Tx
05-26-2004 14:57:38
third party image
