pic of oil pressure relief valve?
souNdguy
05-27-2004 05:12:32
I'm here at work and don't hanve my fo-4 with me.. anyone got a pic of the front o' the engine big spring loaded hex head oil pressure relief valve.. even a line drawing will do if you don't have a 'real' pic.
thnaks
Soundguy
Pic of assembly TIMW(PA)
05-27-2004 10:06:52
 Re: pic of oil pressure relief valve? in reply to souNdguy, 05-27-2004 05:12:32
third party image
here ya go. I'm sorry it took so long I had an appointment to go to this am. Hope this helps...Tim
souNdguy
05-27-2004 10:44:23
 Re: Re: pic of oil pressure relief valve? in reply to Pic of assembly TIMW(PA), 05-27-2004 10:06:52
Don't appologize.. thanks a bundle.
I had some oil system questions for my mechanic at work, and was trying to describe this to him.. and without my manual.. he wasn't getting a good mental picture of it.
I was telling him about the spring... too long.. and oil pressure may get too high.. too short.. and oil may bypass too much.. etc.
again.. many thanks.
Soundguy
Thomas
05-27-2004 10:02:35
I had change my pressure guage during my restoration. It wasn't til later when I finally got the tractor running that I noticed my oil pressure was pegging the guage. Something wasn't right. My old gauge always read somewhere around 20-25lbs. I got a new relief spring then I removed my old one(from the left side without disassembling anything)and compared them. The spring is suppose to stick past the plunger alittle less than 3/4 in. Mine was a whole 11/2in. I installed the new spring, cranked the tractor and the pressure went straight to 40lbs. Exactly what the book says I'm supposed to have.
T
Bob
05-27-2004 08:26:17
third party image
Here's a scan of the relief setup.
souNdguy
05-27-2004 10:47:55
 Re: Re: pic of oil pressure relief valve? in reply to Bob, 05-27-2004 08:26:17
Thanks for the scan too.. great info.. just what I needed between the pics and all.
I'm assuming that is a copper or aluminum gasket?
thanks guys!
Soundguy
TIMW(PA)
05-27-2004 12:48:51
 Re: Re: Re: pic of oil pressure relief valve? in reply to souNdguy, 05-27-2004 10:47:55
The gasket that was on mine was some sort of fiber gasket. It wasn't aluminum or copper although I dont see why one wouldnt work. Just like an oil drain plug on a car or something
Dave
05-27-2004 07:51:17
How do you get at that thing with the engine in the tractor? Please don't tell me ya gotta take out the radiator...
Jeb2N
05-27-2004 08:29:21
 Re: Re: pic of oil pressure relief valve? in reply to Dave, 05-27-2004 07:51:17
No,you don't have to remove the radiator. However, taking either the distributor or the water pump off helps out tremendously. I recommend taking the distributor off as it is easier to get to and replace than is the water pump.
Dave
05-27-2004 06:57:09
Jeb2N
05-27-2004 05:45:04
third party image
This is the closest thing I have. Unfortunately, the big plug is hidden by the coil in that picture.
TIMW(PA)
05-27-2004 05:50:50
 Re: Re: pic of oil pressure relief valve? in reply to Jeb2N, 05-27-2004 05:45:04
third party image
Did you want a picture of the assembly taken apart or just the pic of it on the engine?
souNdguy
05-27-2004 07:00:30
 Re: Re: Re: pic of oil pressure relief valve? in reply to TIMW(PA), 05-27-2004 05:50:50
Thank for the pics guys.
If you have a pic of the assembly I'll take that too.
thanks
Soundguy
