polorizing a generator
Norm
05-27-2004 08:03:30
Please help,
I would like to know the correct method to use to poloriz the generator on a naa 6 volt positive ground. Thanks
Jim Cox
05-27-2004 12:09:18
 Re: polorizing a generator in reply to Norm, 05-27-2004 08:03:30
The 'best' way, but not the only way, to polarize THIS generator ( please note the all caps disclaimer ) is to jumper the Batt terminal on the VREG to the FIELD terminal on the VREG. Then you're applying max current to the field windings while NOT causing current to flow thru the armature. This only works on B-Circuit gennys. trust me on this one.
Jim Cox
Stealth Generator Guy
souNdguy
05-27-2004 08:12:36
On an NAA with stock B-circuit genny, AFAIK, you jumper batt and field at the regulator.
If this is wrong I'm sure Jim Cox will correct it.
Soundguy
gahorn
05-27-2004 09:52:52
 Re: Re: polorizing a generator in reply to souNdguy, 05-27-2004 08:12:36
Momentarily connect BAT and ARM terminals on the regulator. (Never the FieLD. Ground the FLD term to troubleshoot a generator. If it puts out with the FLD grounded then the gen is OK.)
wrong genny . . . Dell (W
05-27-2004 10:02:50
 Re: Re: Re: polorizing a generator in reply to gahorn, 05-27-2004 09:52:52
Horney..... ..the NAA genny and V/R uses a DIFFERENT POLARIZING PROCEDURE because it is what is called a "B" circuit.
Your procedure is correct for the "A" circuit 8N 3-wire genny and 4-terminal squarecan V/R.
Its good that neubies (and us ol'timers) to ask questions about obscure procedures..... ..respectfully, Dell
gahorn
05-27-2004 13:00:18
 Re: Re: Re: Re: polorizing a generator in reply to wrong genny . . . Dell (W, 05-27-2004 10:02:50
This was just a test to see if you were paying attention, Dell! (grin) Thanks for the correction.
Norm
05-28-2004 06:47:31
 Re: Re: Re: Re: Re: polorizing a generator in reply to gahorn, 05-27-2004 13:00:18
Thanks for all the tips guys. I tried field to batt at the voltage regulator and that did not correct the problem. The meter show a discharge when the motor is running. Is it time for a new regulator or generator?
Norm
Dell (WA)
05-28-2004 07:20:05
 Re: Re: Re: Re: Re: Re: polorizing a generator in reply to Norm, 05-28-2004 06:47:31
Norm..... ...yes, good bet, bad squarecan voltage regulator for your NAA. Don't forget to "polarize" your new voltage regulator. Theres usually a tiny sheet of paper in the V/R box with instructions in 6 languages 'cept 'murricum. But who reads instructions, eh?..... ....Dell
Norm
05-28-2004 11:55:19
 Re: Re: Re: Re: Re: Re: Re: polorizing a generator in reply to Dell (WA), 05-28-2004 07:20:05
Thanks for the info Dell. I will try a new one Norm
