12v help.
Adam(IN)
05-28-2004 11:14:41
I just bought a 12v conversion kit and a 12v roundcan coil for my 8n with sidemount distributor. Question is the new coil says use only with external resistor. I did not think that resistors were needed if the coil was same as the alternator?
Any help would be great.
Dell (WA)
05-28-2004 11:39:12
 Re: 12v help. in reply to Adam(IN), 05-28-2004 11:14:41
Adam..... ..you'be become the "victim" of corporate americal's downsizing and consolidation. What you really have is essentually a 6/8 volt universial "one-size fits all" inventory savings ignition coil that requires an external resistor to operate on 12 volts but you can also use the same "12 volt coil" for the rare 6 volt tractor application without a resistor.
Real mechanics understand the need for a "ignition switch" operating resistor bypass for start-up and then runing with a resistor that was already installed in the car.
You have a tractor. You need a REAL 12volt IGNITION COIL that doesn't use an external resistor. NAPA IC-14 12 volt coil has been recommended. Or a 12 volt Volkswagon coil would also work. Or a 12 volt "HOT-ROD" coil ...OR... you need an external ignition resistor like RU-100 would probably do.
Doesn't that gripe you that you buy a kit to get all the right parts and you end-up with a "wrong" part? And don't forget, your ignition coil polarity is (+) to (+). That means the 12 volt alternator's DEMAND for NEGATIVE GROUND requires the ignition coil (-) terminal be connected to the distributor POINTS and the coil (+) connected to the ignition switch..... ...Dell, a 12 volt advocate for the right reason
