Pertaining to the SHORT governor to carb rod... What you are trying to do is get the governor and carburetor to reach their wide-open point at the same time. Unhook the rod at the carb end. Rotate the carb throttle shaft wide-open (opposite the direction of where it is stopped by the idle screw). Hold the rod end up to the ball on the carb lever. If all is OK, the rod will be in position to snap back on the ball. If the position of the rod end is such that it passes the ball, in the direction beyound the wide-open position of the carb, you probably have excessive wear in the governor, probably in the thrust bearing area. If the position of the rod end is such that reinstalling it would pull the carb throttle shaft back from the wide-open position, you have other problems, such as improper assembly of the governor. The dealer shops had a jig they could set the assembled governor on, and verify the position of the lever that connects to the carb, to verify proper assembly of the governor, or the lever was to be bent, if needed, to get it's position to match up with the jig.
