Gauge of wiring
8ngreenhorn
05-31-2004 10:00:33
First off, I ordered my repair manual, but I can't wait to screw something up so I want to do some simple preventative stuff. I just got an 9N with 8N engine- and it needs work. Used to start 'till I changed oil and hydro fluid. Now it won't even turn over. I don't think there could be any coorelation, so I'll replace the solenoid and regulator first. Been rainin' a good bit, so I figger 'sgotta be electric. Anywho, If I replace the wiring, must I use many differnet specific gauge wire, or can I get away with just maybe two sizes.
Thanks you guys. You make punks like me appreciate your wisdom, or at least busted knuckles...
souNdguy
05-31-2004 15:51:52
 Re: Gauge of wiring in reply to 8ngreenhorn, 05-31-2004 10:00:33
Don't start throwing expensive parts at it blindly just uet. You'll have time to spend money later.
Unless the v-reg is completely fried.. it woun't prevent the starter from turning over.
How do you have the starter setup? Using a new switch and the oem starter solenoid.. or using the 9n built in starter switch behind the steering column.
Do some checks with your vom first..
Soundguy
JohnMD
05-31-2004 13:12:29
I would buy a wiring harness. If you use the same color wire for everything you will have a tough time determining what wire is connected to what terminal. Trouble shooting would be almost impossible.
Jon in Mass
05-31-2004 12:17:15
When you say it won't turn over, do you mean the starter doesn't even run? Do you get a click or nothing at all?
Wiring Harness..John,PA
05-31-2004 11:30:16
You might consider purchasing a complete new wiring harness for about $14.00 at your local TSC store, or perhaps from the sponsors of this web site.
