Replacing rear axle oil seal on 2N
Ronald
05-31-2004 15:16:34
Can anyone give information on how to replace rear axle oil seal on 2N Ford. Thanks!
JohnMD
06-01-2004 05:11:52
 Re: Replacing rear axle oil seal on 2N in reply to Ronald, 05-31-2004 15:16:34
Various suppliers on the web sell a video on replacing brakes and seals. The video cost around $25 but is well worth it.
Matt(MN)
05-31-2004 15:52:43
You can save yourself a lot of work and pick up a pair of sure seals. They slide over the axle shaft and fit into the axle bearing. Pack the axle bearings with grease before installation as the sure seal prevents tranny fluid from spilling into the axle bearings as a lube. The hardest part of using sure seals is getting them started evenly into the bearing. Take the seal to a grinder and narrow the lip of the base to help get it started. Good luck.
