Serial Number ?N25113 What model and year is it?
Ron
06-01-2004 05:10:07
I just bought a Ford and cant read the first number of the serial number its stamped ? N 25113 its got a three speed trans so it must be a 9N or a 2N? The dist is mounted under the water pump and I checked the numbers. Would it be a 1940 9N tractor??
Thanks
Ron
Jim.UT
06-01-2004 08:22:23
 Re: Serial Number ?N25113 What model and year is in reply to Ron, 06-01-2004 05:10:07
It looks that way. You can click the link below for more clues to confirm the age of your Ford.
daz
06-01-2004 05:19:09
My 1940 9N is 25723. daz Ohio
Dan
06-01-2004 05:17:48
Yes, that is a 1940 9N tractor, unless the engine has been swapped out with an early model 1947 8N engine.
Good luck,
Dan
TIMW(PA)
06-01-2004 05:16:42
yep...1940 9N...to the left under research info is a list for serial numbers. HTH..Tim
