Gas, spark but no go
Andrew
06-01-2004 14:56:56
I went out to start my tractor yesterday and it wouldn't start. it has been running fine. i have gas in the carb and spark but it won't fire. i put some starter fluid in the plug holes and that fired just fine, but if i put starter fluid in the carb it doesn't do anything. i cleaned the carb out so i know it is not clogged. could i have an air leak some were that would keep it from firing? is so, were? any other ideas? thanks for any help.
Steve IA
06-02-2004 03:24:03
 Re: Gas, spark but no go in reply to Andrew, 06-01-2004 14:56:56
What happens when you cover the air intake of the carb and crank the engine? Is there any suction? Steve 8N I69302
Danny in CO
06-01-2004 15:24:47
Andrew,
When was the last time it ran? If it has been some time, you could have either stuck valves or stuck rings. With the up-draft carb, you have to have compression to pull the gas/air into the cylinders.
Danny
Andrew
06-01-2004 15:46:47
 Re: Re: Gas, spark but no go in reply to Danny in CO, 06-01-2004 15:24:47
I ran i last saterday. so it hasn't been that long.
Danny in CO
06-02-2004 07:20:26
 Re: Re: Re: Gas, spark but no go in reply to Andrew, 06-01-2004 15:46:47
Andrew,
I still suspect compression. If you have a compression guage, do a compression test, first dry and then wet (with a spoonfull of oil in each cylinder). Minimum is 90 psi in each cylinder. If you get a large increase with the wet, you have worn rings. If your compression is OK, you could have a blocked air cleaner. Disconnect it and try opening your throttle about 2/3 and squirt starting fluid directly in the carb again not in the air cleaner.
Danny
