hyd.control valve
pete
06-01-2004 18:33:20
How do you adjust the hyd. controll valve on a 8n?Seems,IM GETTING TO MUCH PRESSURE AND BLOWING GASKETS.
Fessman
06-01-2004 18:51:07
 Re: hyd.control valve in reply to pete, 06-01-2004 18:33:20
The relief valve is non adjustable. They are not all that expensive either, about $20-25. You should put a pressure gauge in on the system before you change the relief valve. The pressure should be about 1500psi.
Fessman
