Piston Pump Rebuild
ray
06-04-2004 05:26:56
anyone have any advice on rebuilding a piston pump on my Golden Jubilee
Ramon
06-04-2004 08:58:19
 Re: Piston Pump Rebuild in reply to ray, 06-04-2004 05:26:56
It is a bit involved and you need several "special" Ford tools. However, I used to rebuild Ford piston pumps regularly. You need a special tool to remove the ball seats. Pretty pointless to try to rebuild without changing these. Another tool is needed to remove the plate from the pump head. There is ONE (only!) bolt hole that is slightly oversized to allow the plate to be tapped out. You can grind up a 1/4 inch punch to do this. Another special tool is needed to change out the front seal and bearing.
