New one on me
Rich[Wi]
06-06-2004 08:46:34
Last Fall before I put it away for the winter my NAA was dripping a little oil from around the steering gears. Yesterday I was mowing the field road with the Bushhog when my foot slipped off the right running board. Looked down and there was oil everywhere. There was so much I couldn't tell where it was coming from. Back at the shop, after cleaning everywhere I couldn't find any cracks or loose bolts. Took the battery out and I found that the oil was coming from the oil gauge. Tightened the oil line, started the tractor up, and really had oil gushing out. Took it all apart and found the brass fitting that holds the oil line to the gauge had split. I've had them vibrate loose. I've had them not seat right. Never had one split before.
pat
06-07-2004 06:09:31
 Re: New one on me in reply to Rich[Wi], 06-06-2004 08:46:34
I know where you are coming from, had the same thing happen on my Fergy, split right on the bottom couldnt see it until I tightened up, learn something new evereyday,pat
Russ in SoCal
06-06-2004 11:22:38
That's courtesy of the guy who said, "That blankety-blank ain't gonna vibrate loose NOW."
Rich[Wi}
06-06-2004 16:38:35
 Re: Re: New one on me in reply to Russ in SoCal, 06-06-2004 11:22:38
Probably what happened.
Fast Ed Ohio
06-06-2004 23:40:47
 Re: Re: Re: New one on me in reply to Rich[Wi}, 06-06-2004 16:38:35
Sounds like you got lucky, real lucky , blowing oil could have been a major event .
