Mowing in Draft position???
RDut
06-07-2004 07:34:06
Hi All
I was reading my NAA manual the other day and in the section about what position your hydraulics should be in when using a certain implement I saw they recommend using draft control when brush hogging and not position control like I was taught. Has anyone tried this?? Does it work and what are the benefits of doing it this way??
Cheers
Rob
Dell (WA)
06-07-2004 07:48:11
 Re: Mowing in Draft position??? in reply to RDut , 06-07-2004 07:34:06
Rob..... ...you might want to re-read yer NAA manual. Draft control "varries" the depth (inverse of height) of the plow depending upon the "drag/draft" of the plow after you bury the plowshare in the soil. I don't think you want yer mower to be constantly moving up and down as you mow heavyer then thinner stands of grass. That is what position control is supposed to control. Constant height..... ..Dell
RDut
06-07-2004 08:07:31
 Re: Re: Mowing in Draft position??? in reply to Dell (WA), 06-07-2004 07:48:11
Hi Dell
That is what I thought also, which is why I asked. I will double check again tonight
Cheers
