Question for dell
Reno J.
06-08-2004 14:11:48
Dell youve stated before not to use GL-4 or GL-5 in tractors because it will damage certain type of metals? I use it in my tranny and diffy in my Jubilee. please expand. thanks Reno J.
souNdguy
06-08-2004 14:34:49
 Re: Question for dell in reply to Reno J., 06-08-2004 14:11:48
The hyd/pump in a 9/2/8N resides in the rear diffy/tranny hyd common oil sump. The hyd pump has yellow metal cam blocks. Gl-5 oils harm yellow metal.
Your NAA has a completely seperate hyd system that is engine driven.. and has its own hyd sump. the rear end has its own sump... etc.
Soundguy
good answer . . . Dell (W
06-08-2004 21:14:15
 Re: Re: Question for dell in reply to souNdguy, 06-08-2004 14:34:49
Good answer, 8N's single hydraulic sump system is different than NAA's 3-sump system. Hassta do with the "Handshake Littigation and Pattent Infringement Suit" between Ferguson Tractor and Ford Tractor..... .Dell
txblu
06-09-2004 06:04:57
 Re: Re: Re: Question for dell in reply to good answer . . . Dell (W, 06-08-2004 21:14:15
Well that makes sense. Nothing else did.
