Reid..... ..itz'chur sparkies. Your frontmount ignition coil gitts hot has melted its insulative tars and shorted out some of its windings. When cold, the tar insulates and you gitt strong enuff sparkies for starting. I make any old sparkie plug into a "calibrated" sparkie tester by bending the side electrode outward to a full 3/16" gap (instead of 0.025) and clamp the tester to a bolt. Iff'n I can't draw a snapping blue sparkie while crankin', BAD SPARKIES. There is some merit to the claim that continual usage of ether quick start will make yer engine an ether addict. Sumptin ta tink'bout. Iff'n yer constantly having to use quick start, you might be nearing "rebuild/overhaul" time. I'd suggest you do the dreaded "compression test". Ford specs: 90 psi min (dry). Do 5 puffs min and ritter down. Then squirt about 1oz of oil down the sparkie hole to seal the rings and do 'nutter' "wet" compression test. Writter down. The change in compression values will be a BIG CLUE to the health of yer engine. Less than 10psi, healthy engine; 20psi, well used engine; more than 30psi, very tired engine and ether is a crutch that is just delaying the eventual need of rebuilding; NO change in psi, burned exhaust valves..... ....respectfully, Dell
