I can't comment specifically on the 6v e-ignition.. I havn't seen one. I would put your volt meter on the top post, and see what you have while cranking. If there is an additional power feed to the module.. see what it has while cranking. I'm surprised to find that the kit wants you to use no resistor in line with the old style coil. Unless it is compensated for by the design of the module. If I had to -guess- and that is what this is.. a BIG guess. I would say the module is very sensitive to low voltage.. and then when cranking your tractor over, that threshold is crossed. Try hooking it all back up.. turn on your key.. but jump the tractor's starter from another battery.. even a 12v one. Just don't hit the starter button.. that will keep the ignition and starter circuits isolated. If it starts fine like that.. sounds like the voltage on your battery drops too much due to starter load.. bad cables, dirty connections, or a bad starter. Only a WAG.. Soundguy
