3 pt. hydraulic rebuild cost?
Ron
06-10-2004 13:33:59
Gotta question.... what should it cost to have a tractor shop rebuild thge hydraulic pump on a 8-N 3 point lift?
Is this much of a project?
I have a tractor that the 3 point raises slowly and jerkily then starts to drop in a matter of minutes. I am presuming this means it needs an overhaul?
Steve IA
06-11-2004 04:38:05
 Re: 3 pt. hydraulic rebuild cost? in reply to Ron, 06-10-2004 13:33:59
You may not need a pump rebuilt. I'd troubleshoot it and fix the easy/cheap stuff 1st. See the link below. Comeback with any specific questions. We're open 24/7. Steve 8N I69302
It's stinky! Rob
06-10-2004 14:00:03
Nothing too tricky though.
D Masury
06-10-2004 13:44:28
Having just rebuilt my hydraulic pump I would recommend doing the job yourself..... With a manual and the helpful people on this discussion group you can do the job yourself pretty easily.. the worst is that your will get a bit greasy, the best is that the cost will be minimum and you will learn a lot about your tractor.
