Small lever on Rt side under seat
Rich
06-11-2004 12:58:47
The small lever under the seat as one sits on it, what does it do exactly? Moves for and aft. I think it is a terrain follower but not sure in what position it does what. Help!!
Rich
Larry 8N75381
06-11-2004 17:43:17
 Re: Small lever on Rt side under seat in reply to Rich, 06-11-2004 12:58:47
Rich,
I have linked a previous reply that should help you understand the differences/uses of draft and position control.
Regards,
Larry
Leemo
06-11-2004 13:11:49
8N or NAA tractor I presume. That would be a lever to switch between draft control for plowing or position control so the implement on the 3 point hitch stays in the same position instead of going up and down while you're using it. Up for position control and down(forward) for draft control if memory serves me correctly. If not somebody will correct me. These guys know their stuff.
Later, Lee
