Order Ford 9N Parts Online
9n head stud broken
Rick
06-12-2004 16:10:21
Help! While romoving my 9n head a stud broke in the block. Does counterclock wise remove it. I have tried an ease-out and it feels like it will break also. Tried channel locks and vise grips too. About 1 and 1/4" sticking up out of the block.
Thanks, Rick
Rick
06-14-2004 11:04:24
 Re: 9n head stud broken in reply to Rick, 06-12-2004 16:10:21
Thanks for all the advice, BP, Smacking it, and a stud removing tool worked after soaking and working at it for a day or two. Got new stud and now waiting on Fedex to deliver the head.
-Rick
STAREYES
06-13-2004 09:46:50
RICK TRY PUTTING WD40 TO REMOVE ANY RUST AN HEAT WITH TOURCH TO HELP BREAK BOLT FREE AND GO WITH THE VISE GRIPS, REMBER THESE ARE TORQUE IN PLACE THIS SHOULD TURN IN SAME DIRECTION AS OTHER HEAD BOLTS. GOOK LUCK STAREYES
Jeb2N
06-13-2004 04:51:07
See my reply below on your duplicate post
souNdguy
06-12-2004 20:55:21
If all that fails, fellow listmember Zane has recomended taking a nut and sliding or threading it down on the broke stud and then weld it on. Usually the heat of the welding helps break it loose anyway.. and the nut gives your wrench something to grab onto. Hint... put something over the deck of the block to protect it from slag and splatter when you weld the nut on.
Soundguy
Rob
06-12-2004 17:24:32
Rapping on the end will help.
Rick
06-12-2004 18:34:20
 Re: Re: 9n head stud broken in reply to Rob, 06-12-2004 17:24:32
Do you turn the stud counterclockwise to remove it?
Rob
06-12-2004 18:37:56
 Re: Re: Re: 9n head stud broken in reply to Rick, 06-12-2004 18:34:20
Sure. CCW.
Wack it square on the end a few times. Lay a broad tool on it so you don't make a glancing blow and wack it. It will come out.
hvw
06-12-2004 17:16:03
Rick, if you have a choice between PB blaster or Kroil, get the Kroil. It's hands down the best I've ever seen. Comes from Kanolabs.com if you can't find it locally.
wer-fl
06-12-2004 16:33:04
Don't use an easy-out if the stud is above the hole. Heat the stud and place a bee wax candle while hot on the base of the stud. Let cool. Also use Krorl or PB Blaster on the stud once or twice a day for a couple of days. Then use a small pipe wrench on the stud. It will turn out. Be patient.
