Sherman Trans
8N Puller
06-15-2004 05:40:54
Does anyone know where I can get a good reasonably priced Sherman for tractor pulling? I need the lower gears. Thanks.
JERRY COOPER
06-15-2004 08:00:04
 Re: Sherman Trans in reply to 8N Puller, 06-15-2004 05:40:54
I am parting out a 51 8-n with a side shift sherman transmission with high low range
and am asking $350.00 my phone #(281) 744-4935
and located in the houston tx area, good luck...
souNdguy
06-15-2004 05:51:29
You pulling stock or with a souped up engine? While I think the sherman will work with the 27hp engine the N has with no problem.. I bet it will fly apart under high torque loads that a upgraded motor may put out. You do know the sherman pre-tranny is about the size of a grapefruit right? not gonna be a stump pulling machine either..
Ebay has an underdrive or combo out every now and then... price varies from 300 - 750 depending on which of the 3 common flavors you find..
Good luck
Soundguy
8N Puller
06-15-2004 06:08:21
 Re: Re: Sherman Trans in reply to souNdguy, 06-15-2004 05:51:29
Its a stock tractor. My 8 & 12 year olds pull it for fun. This past weekend they got first and second in the 2500# class.
souNdguy
06-15-2004 06:11:43
 Re: Re: Re: Sherman Trans in reply to 8N Puller, 06-15-2004 06:08:21
Sounds neat.
Good luck
Soundguy
