Ron..... ..yer reports of 1-1/2 turns on yer carb adjusts and then they have "no effect" concerns me. The fact that yer engine don't take a throttle increase, implies TOO LEAN ...or... bad governor with flat balls and grooved race. I adjust the DOWNpointing mainjet to 1-1/2 turns and LEAVITT. I then adjust the SIDEpointing idle mixture for maximum idle rpms, not smoothest idle, MAX idle rpms. My idlemix usually about 3/8 turn. Idle rpms is a SLOOOooow 400 rpms, set by the behind throttle screw. Remember, idlemixture is BASSACKWARDS, out for lean and in for enrich. I check the governor while engine is running by trying to "hand-jazz" the carb-govr throttle rod. Does it fight you? as you try to increase engine rpms? Do it, it won't byte ya. Iff'n yes, probably good, iff'n it don't fight ya, probably worn governor. Check yer I&T FO-4 for more governor checkout procedures..... ....Dell
