position control lever
Patpa
06-21-2004 12:32:25
I have a 51 8n. The position control lever (the little lever under the seat)is very hard to move. The hyraulics work fine but the lever takes a lot to pull it up into position mode or push it down into draft mode. What could be going wrong inside. This just started to happen. It use to move easy.
Thanks for any advice.
Pat
ZANE
06-21-2004 19:15:07
 Re: position control lever in reply to Patpa, 06-21-2004 12:32:25
It is possible that the cam follower pin has worn enough to let the pin slip off the side of the cam and is making the position mechanism bind on the side of the lift housing. Also a cotter pin may have fallen off the position mechanism.
Remove the right side inspection plate and with a mirror inspect the innards.
Zane
