PVF..... ...what aren't you telling us? The 1-terminal squarecan OEM 6 volt frontmount ignition coil ABSOLUTELY must have its "infamous ballast resistor" in its ignition switch circuit. Otherwize, the ignition coil will melt its internal insulative tar and short out some of the primary windings. Ballast resistors are like lightbulbs, they eather work or they don't. (unless someones been muckin'round) Its simple to checkout the 1-terminal squarecan ignition circuit with yer eyeballs. Start at the coil terminal. That wire should go thru the sparkies tube directly to oneside of the "infamous ballast resistor" mounted on the backside of your dashpanel under the ammeter. The otherside of the ballast resistor should be connected to the ON side of your ignition switch. The otherside of your ignition switch should be connected to the bottem center battery power termanal of the insulated ballast mounting board. Iff'n ya gottza 12 volt conversion, all bettz are OFF because there is no "official standard" way to electrically wire the ignition coil. But the scheme is still the same. Ya gotta have a resistor in yer frontmount ignition coil circuit somewhere or it will puke its guttz..... .....respectfully, Dell
